Suzuki Jimny Steering Damper Kit, the best?
- jimknows
20 Aug 2016 22:05 #171496
by jimknows
Suzuki Jimny Steering Damper Kit, the best? was created by jimknows
Hello,
Im pretty sure most of you use steering damper, but which ones you prefer?
Seen trail master, rough country, pro comp, rancho..
Are they basically the same as in results ??
- Thank you received: 225
21 Aug 2016 01:48 - 21 Aug 2016 07:36 #171499
by zukebob
Replied by zukebob on topic Suzuki Jimny Steering Damper Kit, the best?
I can't compare it to others but I'm happy with my ToughDog RTC damper. I would only suggest it for a right hand drive, though. Due to having to mod the brackets to fit my LHD, I wouldn't replace it with another. If yours is RHD, the TD should be a decent choice.
I would expect most steering dampers to perform about the same during the life of the damper. If not choosing a TD, I would suggest going with one from a company that you know makes good quality components. Trail Master is likely a good choice. I think Bilstein also makes a steering damper that would fit.
Last edit: 21 Aug 2016 07:36 by zukebob.
- Thank you received: 923
21 Aug 2016 09:26 #171515
Replied by X8GGY on topic Suzuki Jimny Steering Damper Kit, the best?
Funny you should mention a Return-To-Centre (RTC) Steering Damper, as I've just fitted one to my Jimny -
It's a Land Rovery Discovery 1 / Range Rover Classic one and was a bit of a squeeze to fit,...
About time someone imported some Tough Dog ones over to the UK then!
- Thank you received: 1847
22 Aug 2016 04:15 #171553
Replied by Lambert on topic Suzuki Jimny Steering Damper Kit, the best?
Does that give you full lock when you go left hand down, because in that picture it doesn't seem to have much travel left before the piston is fully compressed?
- NicBeeee
22 Aug 2016 18:50 #171569
by NicBeeee
Replied by NicBeeee on topic Suzuki Jimny Steering Damper Kit, the best?
Looking to fit a damper and it is next on my list, I tend to only get a wobble on one piece of road in the whole of Leicetsreshire, sadly it is the road that leads to our village, I dont want to pay for the full kit as I can make the brackets myself, can somebody kindly tell me the optimum size that suits the Jimny.
Thanks
Nic
Thanks
Nic
- JimnyMax
23 Aug 2016 07:34 - 23 Aug 2016 07:43 #171582
by JimnyMax
Replied by JimnyMax on topic Suzuki Jimny Steering Damper Kit, the best?
S200KYS I have the Armstrong STC786 which is also an LR Disco 1 damper. Where did you get the bracket?
Last edit: 23 Aug 2016 07:43 by JimnyMax.
Time to create page: 0.484 seconds
