KOYO DG357222DW
- Thank you received: 115
20 Aug 2016 14:07 #171470
by maverick
Jalapeño, IISY?
KOYO DG357222DW was created by maverick
Is the KOYO DG357222DW sutiable for a Rear Wheel Bearing?
Jalapeño, IISY?
20 Aug 2016 17:54 #171479
Replied by mlines on topic KOYO DG357222DW
yes
20 Aug 2016 20:08 #171489
by maverick
Jalapeño, IISY?
Replied by maverick on topic KOYO DG357222DW
which way around does the bearing go on the shaft?
Jalapeño, IISY?
20 Aug 2016 20:15 - 20 Aug 2016 20:16 #171492
As per the Wiki page
www.bigjimny.com/mediawiki/index.php/Rea..._Bearing_Replacement
The lip (ie. the built in spacer) goes to the outside.
If fitting to an old SJ (I know you have a Jimny) then make sure you have removed the old separate spacer from the driveshaft first as it can be hidden in the corrosion.
Last edit: 20 Aug 2016 20:16 by mlines.
Time to create page: 0.078 seconds
