Wont start HELP!
  • wilku
10 years 3 months ago #171422 by wilku
Wont start HELP! was created by wilku
What do you mean by completely dead? Did your radio / combination meter switch on and it was just the starter motor that didn't work? Or was there no current in the car AT ALL?
Or did the starter motor turn, but the engine didn't want to start?
  • wilku
10 years 3 months ago #171424 by wilku
Replied by wilku on topic Wont start HELP!
I'd start with the biggest one first - the 80A in the fuse box just next to the battery. And then the others in this box.
And - for the sake of double checking everything - are you 100% sure that you have connected the other battery the correct way (+/-)?
Because if the car was reacting to low power on the original battery but there was no reaction at all when you plugged the bigger one the issue must be about the connections, polarity and / or fuses.
How exactly did you connect the other battery? Have you replaced the original one? Or have you connected the bigger via cables to the original one?
  • wilku
10 years 3 months ago #171441 by wilku
Let me know if you find the reason - I am really curious, as once I had a really ridiculous situation with my Jimny not wanting to start:
I stopped the car as usual, closed it and went home. When I came back and wanted to start it it acted as if there waas almost no energy in the battery, so I recharged the battery and tried again - the result was the same, although the battery was fully charged.
I looked around the car in despair and found.... the door window switch being stuck between lift and neutral position. Pushed it back to neutral and.. the car started as if nothing happened! Seems that the switch needs a replacement. Or careful operation :)
Time to create page: 0.080 seconds
