broken spring
  • talby2491
10 years 3 months ago #171278 by talby2491
broken spring was created by talby2491
Ive broken one of my rear coil spring on one side it has a yellow label on the other green I know you can get diffrent colour springs but which colour would you use to try to make the ride more comfy instead of it being glued to every bump and hole thanks in advance was going to use standard off a vitara but dont no if it will work
  • mickt
10 years 3 months ago #171294 by mickt
Replied by mickt on topic broken spring
The springs dictate the ride height, the dampers control the response so would be the item to change to alter the ride comfort. ideally the springs should be replaced in matching pairs for safety issues and to balance the ride height.
10 years 3 months ago #171411 by Rhinoman
Replied by Rhinoman on topic broken spring
The springs control the ride, the dampers are there to damp the response of the springs - that's why they are called dampers. The dampers should be chosen to match the springs.
Time to create page: 0.081 seconds
