Yet another 4WD light thread
- wilku
13 Aug 2016 12:47 #171277
by wilku
Yet another 4WD light thread was created by wilku
I've read a lot of topics and guides and manuals about 4WD system behaviour and malfunctions, but I haven't found anything similar to my case, which is as follows:
So in general the 4WD works fine both in high and low range, however I'm a bit concerned about the wear of the front axles and shaft due to the hubs not disengaging.
Anyone has any ideas on what the main culprit may be? Vacuum pipes? Transfer case switch? Where do I start looking?
- Moving the lever from 2H to 4H doesn't trigger the 4WD light when done once.
- On second attempt (i.e. 2H-4H-2H-4H) the light turns on
- I suspect the hubs are not DISengaging
- wilku
21 Aug 2016 11:46 #171520
by wilku
Replied by wilku on topic Yet another 4WD light thread
I see that nobody has any ideas, so I decided to switch to manual hubs. I intend to remove all vacuum-related elements and my question is about the control of the 4WD light. Normally it's operated by the 4WD controller via a blue cable once it receives current via blue/black cable.
So - can I remove the 4WD controller completely and just short the blue and blue/black cable, so that the dash light is switched on by the switch in the transfer case directly?
I mean - I know the dash 4WD light should work, but the question is if I can remove the controller at all? Or would it make the ECU throw some error and/or possibly trigger the "check engine" light?
21 Aug 2016 20:34 #171542
Replied by helijohn on topic Yet another 4WD light thread
I have a post somewhere on stopping the light. Just can't find it at the mo.
You do right to go manual.
However, I had something similar on my Paj and it turned out I wasn't using the stick properly.
- wilku
22 Aug 2016 07:40 #171555
by wilku
the thing is, that I don't want to stop the light
Stopping it is really simple: remove the light bulb or unplug the blue cable from the combination meter plug.
However, I want it to work when 4WD is engaged. And this will be simple.
The question is: can I remove the 4WD controller without causing ECU throw an error?
25 Aug 2016 19:13 #171669
I was meaning stopping it flashing.
wilku wrote: the thing is, that I don't want to stop the light
- ME13OSE
25 Aug 2016 19:46 #171672
by ME13OSE
Replied by ME13OSE on topic Yet another 4WD light thread
I switched to manual hubs last weekend, cut both vac pipes just after the controlled on the inner wing and blanked all 4 cut ends off with some screws. Put the stick into 4wd and instant green 4wd light on the dash. No hassle.
Time to create page: 0.096 seconds
