Venturi plug
  • mickt
10 years 3 months ago #171208 by mickt
Venturi plug was created by mickt
If it was there originally then yes its needed I would have said. As regards the head gasket I would have thought that as it has not had any heat cycle through it then a second re-torque wont hurt. As for the head bolts as they are stretch bolts then I would suggest they are not re-torqued.
10 years 3 months ago #171228 by facade
Replied by facade on topic Venturi plug
The plug is to restrict the oil flow to the cam. Without it you may get oil leakage from the cam seals, there may be too much oil at the top end and you start burning it through the vent, or worse, the front main bearing may have reduced oil flow, because too much is turning off to go to the head.
I'd take it apart again and fit it.
I'd likely reuse the gasket too, if a new one is £1,000,000 from Suzuki :ohmy:
The bolts are not stretch bolts AFAIK, you just torque them up to a reasonable value, so I'd use them again too.
Time to create page: 0.069 seconds
