Greasing prop shaft question
- NineCherries
09 Aug 2016 21:09 #171188
by NineCherries
Replied by NineCherries on topic Re:Greasing prop shaft question
Coolio. Only a few pumps it'll be then.
I've never greased this during my ownership and I've no idea when it was last done, should I be doing anything else to make sure the grease is in the right bit?
10 Aug 2016 08:29 #171205
by facade
Replied by facade on topic Greasing prop shaft question
If you really want, you could take the propshaft off, pull the sliding joint apart, and clean all the rust out of the rubber boot, smear everything with grease & reassemble. (Like I just have, as I had the gearbox out.)
Or just give it a squirt of grease & don't worry about it, it isn't like it is in constant use.
Time to create page: 0.078 seconds
