Brake Lines
- Iansea
10 years 3 months ago #171033
by Iansea
Brake Lines was created by Iansea
After replacing the front brake pads, freeing off and lubricating the caliper pins I jumped in the beast and gave the pedal a couple of pumps to bring the caliper pistons into position. The pedal started firming up and then went slack. After checking the flexi hoses in case I had damaged one I noticed a fluid leak at the back of the car. One of the front to rear pipes seems to have split where it goes over the top of the rear spring mount. Looks like it will be a pig of a job to replace so any tips would be welcome.
Thanks
ian
Thanks
ian
- MWells
10 years 3 months ago #171034
by MWells
Replied by MWells on topic Brake Lines
It's a good job it happened like that and not on the road. I replaced mine when I had my jimny, you're correct it is a pig of a job. In terms of any advice for doing it, the unions on mine were stuck solid and took a pair of stilsons to shift and having a 2 post lift helped. Good luck
- Iansea
10 years 3 months ago #171035
by Iansea
Replied by Iansea on topic Brake Lines
Have the stillsons but not the lift. Any work will have to be done lying on my back. What size pipe did you use? I've seen 3/16 pipe advertised as being suitable for the Jimny but I would have thought it would be metric.
- MWells
10 years 3 months ago #171036
by MWells
I used 3/16 copper nickel pipe.
Time to create page: 0.078 seconds
