ET value issue ?
  • jimknows
07 Aug 2016 11:50 #171069 by jimknows
Replied by jimknows on topic ET value issue ?
Hello, yes...they been checked for accuracy.
When i changed wheels 2 problems accured.
1. suddenly there were some movements / vibrations in the steering wheel when driving about 50mph.
2. the bumpy feeling in the breaks
Because i wasnt to happy with it i called the head office of profile tyre center. I did my research then and another garage said to me that these wheels shouldnt be sold to me because of the difference in ET, and it didnt had the centering set. Therefore the big company (profile tyre center) paid for the adjustments created by the garage. (see photo)
I do feel great with that because i probably own the only jimny with a smooth steering wheel with absolutely no vibrations or whatever. The garage did a great job in creating the solution so the spacer does its work perfectly and the wheel is centered....how hard i drive or hit the brakes, it stays still.
Back to next question, yes they are balanced. But as i understand, when you drive a few months they could be balanced again...
Second, not sure if front and back were swapped....
"have the symptoms with the hqnd brake been replicated with the old wheels on the back"...
As i recall, then there isnt any problem.......all crap started with the new wheels.
Attached are the wheels photo i had before.....and the spacer custom solution created by garage that customizes cars like this...
07 Aug 2016 16:55 #171079 by Lambert
Replied by Lambert on topic ET value issue ?
So you have been to a garage that has the facilities to make a custom set of spacers but when, as i assume you have, you talk to them about the braking issue they what, don't know how to fix it or don't want to get involved because they didn't supply the wheels, i don't understand? If they have the facility half fix it why don't they fully sort it out especially if the original wheel company have admitted liability?
  • jimknows
07 Aug 2016 21:19 #171093 by jimknows
Hello,
The profile T center sold me the wheels. I contacted the importer of the DOTZ hamada wheels and they did said it shouldnt be any problem ....But they suggested a specialised garage who could probable help me. At that moment the complaint was that my stearing wheel was moving and vibrating over 50mph. With the custum spacers they solved that...
But then the problem came what this topic is about....the bumps in the brake. Sure the garage did take a look at it and thats when i said, put on some new brakes at the front...etc...didnt help. They showed me that pulling the hand brake a little it showed it was coming from the rear. So the garage was more then helpfull. But they couldnt find it....
So it is a mistery......
08 Aug 2016 21:46 #171147 by Rhinoman
Replied by Rhinoman on topic ET value issue ?
If its coming from the rear then you should get the drums checked for ovality.
  • jimknows
09 Aug 2016 10:37 #171161 by jimknows
Well, it looks like the situation has changed....i havent tried some things since a long time but now i dont feel anything in the hand brake. Will try new discs .....weird.....its even possible i managed to mess up the discs because of wrong doin...
Time to create page: 0.094 seconds
