Jimny wont start
- dylanaicsremi
03 Aug 2016 11:20 #170876
by dylanaicsremi
Jimny wont start was created by dylanaicsremi
hi
My jimny wont start at all starter motor goes but wont start.
i have just had it back from the garage where the exhaust manifold was welded and new kingpins on front and manual hubs fitted.
everything was fine but a day later it started cutting out on idle, done this a couple of times then it cut out completly when travelling at 50mph then came back on again, then a day later it started then cut out and now wont start at all.
i could hear a buzzing from relay when ignition on so i swapped the 2 relays next to the battery around to see if it was the fuel pump relay still never started.
also before the manifold was fixed their was a management light on obviously because of the lambda sensor when the manifold was blown i presumed, now the light isnt on i cant really remember if it only came on when engine was running??
would a faulty lambda sensor cause this?
any help would be greatly appreciated
Thanks
Thanks
- dylanaicsremi
03 Aug 2016 11:23 #170877
by dylanaicsremi
Replied by dylanaicsremi on topic Jimny wont start
2001 model twincam
- mickt
03 Aug 2016 18:51 #170886
by mickt
Replied by mickt on topic Jimny wont start
Doubt if faulty lambda would cause it to not start. Is it trying to start i.e. partial ignition or nothing at all? if nothing then crankshaft sensor could be the fault as that is what triggers the ignition through the ecu.
- dylanaicsremi
04 Aug 2016 08:24 #170912
by dylanaicsremi
nothing at all.
crankshaft sensor did come to mind
thanks
thanks
04 Aug 2016 11:16 #170922
by Busta
Replied by Busta on topic Jimny wont start
I'd agree with swapping the crankshaft sensor first.
Time to create page: 0.092 seconds
