How to Split a Front Hub?
02 Aug 2016 10:07 #170851 by maverick
Does anyone know how to split a Front Hub - I need to change one of my wheel Studs but removing it is hampered by the ABS Ring ...
Jalapeño, IISY?
02 Aug 2016 13:59 #170857 by Jezz
Replied by Jezz on topic How to Split a Front Hub?
They are an interference fit. When i done mine, I cleaned up arond where the abs ring is seated on the hub, and then used a puller to put some tension on it and tapped around it with a small hitting stick and it popped off. When i put it back on, i cleaned up the mating faces and tapped it back on with a copper mallet. If i was going to do it again, I'd probably try warming the ring up, as it will more than likely just fall off.
It's been fettled just a tad.
02 Aug 2016 14:06 #170858 by maverick
Replied by maverick on topic How to Split a Front Hub?
Thanks Jezz - does the bearing have to come out or can it stay in?
Jalapeño, IISY?
02 Aug 2016 14:19 #170859 by Jezz
I left them in. I filled the centre with rag to stop any crud dropping in the bearings. Then used a bit of scrap plate across the back of the hub so as not to damage the seal and for the puller to have something push against while the legs pulled at the ring, Then gently tapped the ring between the stud flanges and it came off. It did take quite a bit of tapping and i kept adding to the pressure on the puller as i went around.
02 Aug 2016 15:32 #170861 by maverick
Thanks again Jezz ... what Puller (make/model/picture) do you have?
Jalapeño, IISY?
02 Aug 2016 22:52 #170864 by Jezz
The puller is just a cheapo one i got from Halfords i think.
[IMG
Time to create page: 0.105 seconds
