Alternator mounting bracket bolt (bottom)
29 Jul 2016 21:30 #170705
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Alternator mounting bracket bolt (bottom) was created by Mike G
Does anyone know if the alternator on the M13 engine is supposed to have some sort of spacer/bushing on the bottom bolt that the alternator pivots on? I recently had mine off and it didn't seem to have anything there. The bolt seemed a little tight to be nipping up on it's own.
29 Jul 2016 22:29 #170708
by Busta
Replied by Busta on topic Alternator mounting bracket bolt (bottom)
I don't think there is any kind of bush in there, no. As you have no doubt found out, if it is done too tight then the alternator won't move to adjust the tension, so I leave it just slack enough to be able to move the alternator with a tap of a rubber mallet. A bit of threadlock on the bolts stops it coming loose.
29 Jul 2016 22:38 - 29 Jul 2016 23:05 #170709
by Mike G
Replied by Mike G on topic Alternator mounting bracket bolt (bottom)
Thanks Busta,
Was just thumbing through the manual and seen the exploded diagram for the alternator and it looked like some sort of bush was present, but wasn't labelled, nor did it have a line denoting it's location in the assembly.
I did tighten mine up and it's not loose or anything, but wasn't sure if I was putting too much stress on the bolt and stretching it as it made creaking sounds when I horsed it in there.
Last edit: 29 Jul 2016 23:05 by Mike G.
- skywalker65
- Premium Member
- Thank you received: 20
30 Jul 2016 06:12 - 30 Jul 2016 06:21 #170710
by skywalker65
If in doubt ...... Flat out ??
Replied by skywalker65 on topic Alternator mounting bracket bolt (bottom)
There is a bush ,it takes up the clearance between the mounting point on the engine block and the alternator itself. As you tighten the bolt the bush is pushed out slightly to take up any clearance.
Sounds like the bolt threads require cleaning as do the threads that the bolt screws into .
Wurth silver anti seize paste is your friend and a torque wrench.
Don't forget that if you have lubricated the bolt threads that you will have to decrease the torque applied to the bolt as you will over torque the bolt if you do it to the standard setting.
Looking at the diagram also shows the bottom mounting bolt but no description. If memory serves me correctly I think the bolt is m10. So if you hadn't got a bush there it would have a big clearance all round the bolt?
Last edit: 30 Jul 2016 06:21 by skywalker65.
30 Jul 2016 06:45 #170711
by facade
Replied by facade on topic Alternator mounting bracket bolt (bottom)
On mine the pivot mounting is U shaped and a flange goes each side of the lug on the alternator, nipping up the bolt pinches the lug between the flanges.
This relies on the alternator being the correct length, but seems to be one of the things they got right
In The Olden Days with Lucas ACR alternators, the pivot had a sliding bush to take up the difference in case lengths between different output alternators.
Also in The Olden Days we oiled threads before torquing them up as a matter of course (but we died of skin cancer by the time we were 35 :ohmy: ) nowadays they use stretch bolts everywhere to get the required clamping forces that we got by oiling the threads.
Progress is good, innit?
30 Jul 2016 20:54 #170751
LOL :laugh: :lol:
I just do my own thing.
Replied by helijohn on topic Alternator mounting bracket bolt (bottom)
LOL :laugh: :lol:
