4 x 4 light flashing?
  • axe666
21 Jul 2016 21:22 #170329 by axe666
4 x 4 light flashing? was created by axe666
i have had my Jimny about a week now and decided to use the 4x4 on a dirt track, and it was epic. but today i tried to use it on a dirt hill, and the light was flashing on the dash, before it was solid, and when i tried to go up it just went to neutral and rolled back..
sorry i am new and keen to learn what can i say
thanks
axe
22 Jul 2016 00:07 #170338 by zukebob
Replied by zukebob on topic 4 x 4 light flashing?
Did you leave it in four wheel drive for any time when you returned to the tarmac?
22 Jul 2016 08:30 #170349 by Busta
Replied by Busta on topic 4 x 4 light flashing?
Does your jimny have buttons on the dash for selecting 4wd? It sounds like you were trying to select low range? Did you follow the instruction on the sun visor?
  • gilburton
22 Jul 2016 12:47 #170358 by gilburton
Replied by gilburton on topic 4 x 4 light flashing?
  • axe666
25 Jul 2016 00:27 #170484 by axe666
Replied by axe666 on topic 4 x 4 light flashing?
thanks for your replies guys
i have never driven it on 4wd bar the once down a grave track which was so much fun loose sone and some drifting around corners..
i have two gear sticks so its not the newer model, so when i shift it as far as it goes back for 4wd the light comes on in the dash just like it did the first time which stayed solid, but now just flashes...
26 Jul 2016 04:07 #170529 by kirkynut
Replied by kirkynut on topic 4 x 4 light flashing?
There's something wrong with the vacuum system that operates the front hubs. You have three options, 1) chase down the problem and fix it 2)get manual hubs or 3) convert your hubs to fixed as per my guide at the top of the Technical Section.
The auto hubs are problematic.
The following user(s) said Thank You: axe666
Time to create page: 0.103 seconds
