Brake servo corrosion
- Colander
20 Jul 2016 20:15 #170295
by Colander
Brake servo corrosion was created by Colander
My brake servo is a bit of a mess to look at, I need to change the discs and pads and I'm wondering if it's worth getting the servo and master cylinder replaced too. It doesn't seem to be draining much fluid, but it doesn't look great does it. Noticed a few used ones on eBay seem to have suffered too so maybe it's common. Anyway what do you think? If anyone has done it, is it reasonably straightforward?
Thanks in advance
Thanks in advance
20 Jul 2016 20:29 #170296
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Brake servo corrosion
As brake linings wear the pistons have to move so use up fluid from the reservoir. People then to this up as they think it is low. When the pads and shoes are changed the fluid is pushed back into the reservoir, however there is now no room so it spills over. This is usually what causes the corrosion.
Grey pick up Jimny
20 Jul 2016 22:01 #170298
Replied by Daniel30 on topic Brake servo corrosion
Rub down and a bit of hammerite
- skywalker65
- Premium Member
- Thank you received: 20
21 Jul 2016 06:18 #170304
by skywalker65
If in doubt ...... Flat out ??
Replied by skywalker65 on topic Brake servo corrosion
Agree with Dan. The chances of you getting the gland nuts off without damaging the brake lines where they go in to the master cylinder are pretty slim.
Engine bay could do with a spring clean after you've done it and then treat the metal areas with some ACF50
- Colander
21 Jul 2016 20:22 #170324
by Colander
Replied by Colander on topic Brake servo corrosion
Thanks for the replies, I'm not a mechanic and wasn't sure if it was a major concern or not. I'll get some hammerite on it then, to be honest it's a good prompt to go over the whole car with rust protection anyway
Time to create page: 0.105 seconds
