Front bumper 2007
16 Jul 2016 14:27 #170098
Replied by Daniel30 on topic Front bumper 2007
- Thank you received: 706
16 Jul 2016 15:41 #170103
Replied by jackonlyjack on topic Front bumper 2007
drill was the way for my 3
16 Jul 2016 15:53 #170104
by Halford
Replied by Halford on topic Front bumper 2007
Heads look pretty good, stick mole grips on the screwdriver for more purchase,
If they snap off, simply drill out, or leave as they are and cable tie the bumper on
:whistle:
:whistle:
The following user(s) said Thank You: Nevillet
16 Jul 2016 16:23 - 16 Jul 2016 16:33 #170105
thanks guys got a big ratchet with phillips head on it came off a treat
Last edit: 16 Jul 2016 16:33 by Daniel30.
16 Jul 2016 17:48 #170110
- Thank you received: 2004
16 Jul 2016 18:48 #170116
Replied by Lambert on topic Front bumper 2007
The split washer is allegedly there to stop the nut or bolt vibrating loose. It needs to be able to bite as it were into the bolt or nut and the surface it is holding so I would go bolt, plain washer, items to be clamped, split washer and finally nut. Unless the nut is a nylock then I would swap the two washers round.
Time to create page: 0.103 seconds
