Is My Front Diff Knackered???
  • EuanJimny
10 years 4 months ago #170077 by EuanJimny
Is My Front Diff Knackered??? was created by EuanJimny
Evening All,
Currently doing my kingpin bearings, hub seal, wheel bearings etc front end is totally off the ground on axel stands and tonight once i refitted the driveshaft into the front diff i gave them a turn by hand to make sure they were right in, now when i turn one shaft it turns the other side but my front prop isn't turning when i do this. Is this normal?
Cheers Euan
10 years 4 months ago #170080 by Lambert
If the opposite side is contrarotating then yes that is a normal outcome as it is just the planet gears walking around each other. If both ends are observing the same rotation then the prop should also rotate. Without a tricky diff eg locked or lsd the wheels will contrarotate as this is the path of least resistance for the force you are applying by turning the wheel.
Time to create page: 0.124 seconds
