Noise in Reverse
- Thank you received: 227
14 Jul 2016 04:47 - 14 Jul 2016 05:46 #170015
by zukebob
Noise in Reverse was created by zukebob
I just started having a scraping sound coming from the front end when I am moving in reverse. It doesn't occur when I am moving straight back but only when the wheels are turned. With the steering fully locked in each direction, I took a careful look around each tire. I couldn't see anything that they might be rubbing on. I jacked up the front and rotated each wheel and there doesn't seem to be anything touching. The Jimny is still under warranty so I am taking it in to the dealer. I'm tempted to do a little more mechanical digging but hesitate if I'm going to request warranty service. Has anyone had a similar experience?
Last edit: 14 Jul 2016 05:46 by zukebob.
- Thank you received: 2004
14 Jul 2016 05:09 #170016
Replied by Lambert on topic Noise in Reverse
No but have you checked for a stone in the braking components they can sometimes be tricky to find without a strip and rebuild but can manifest as your symptoms?
- gusthegorilla
14 Jul 2016 10:04 #170037
by gusthegorilla
Replied by gusthegorilla on topic Noise in Reverse
Mrs Gus's Jimny did just this a few weeks ago...turned out to be a bamboo bbq skewer jammed in behind the backplate... :woohoo:
14 Jul 2016 17:01 #170048
Replied by Riccy on topic Noise in Reverse
Mine does something similar and have found its the tyres. oddly when i measure gap between the tires and bumper when pointing forwards one is bigger than the other. suspect its had a light bump to the front in the past.
it usually happens when im reversing around a tight corner, though not always. i think the axle moves slightly in the bushes or panhard rod which makes it catch when reversing, but clear on axle stands. only happens on tarmac in 2wd.
im running 215/75r15 BFG ATs on standard rims. this did happen before i did any lift or spacers, just with the bigger tyres. would have though standard tyres wouldnt be a problem tho?
if its under warranty get it checked and show them how to replicate the noise.
15 Jul 2016 00:14 #170061
by zukebob
Replied by zukebob on topic Noise in Reverse
Thanks to all. I'm going to jack up the front and pull both front wheels. Hopefully with better vision I will find the problem before taking it to Suzuki.
- NicBeeee
15 Jul 2016 16:31 - 15 Jul 2016 16:57 #170068
by NicBeeee
Replied by NicBeeee on topic Noise in Reverse
Try adjusting the tensioner on the pulley belt, there is meant to be a min max defection for the belt, should be in your manual
Also if you have got a decent slope nearby then park up put your wheels on full lock, turn off engine and drift backwards, will isolate the problem a little if the noise stops
Last edit: 15 Jul 2016 16:57 by NicBeeee.
Time to create page: 0.106 seconds
