Relocating air con pipe help
- davert85
12 Jul 2016 05:48 #169908
by davert85
Relocating air con pipe help was created by davert85
Hi all, in a few days I shall be fitting my winch to the Jim. Iv gone for the battery tray/split charge/2nd battery etc option thanks to some good advice from some members. Anyway, my problem is I have air con and need to relocate the pipe to allow the winch mount (the one off jimnybits with recovery points) and winch to fit. Is there anyone out there who can advise me on this and possibly has some pics or diagram of what and how etc?
Any further advice and tips would be hugely helpful and gratefully received. If it helps the car is a 56 reg vvt, winch - super winch TS 9500lb, and the mount is then hidden/discreet one from jimnybits as mentioned before.
Thanks in advance
David
Thanks in advance
David
- X8GGY
12 Jul 2016 09:30 #169914
Replied by X8GGY on topic Relocating air con pipe help
According to the listing it fits with aircon?
www.jimnybits.co.uk/shop/jimny/recovery-...oints/prod_1477.html
Here -
Here -
- davert85
12 Jul 2016 12:17 #169916
by davert85
Replied by davert85 on topic Relocating air con pipe help
Hi bud, thanks for the comment. I did see that, but I believe you still need to relocate the pipe. As in, it's fits with air con.....you just need to wiggle a few things about.
Can anyone say for sure? Straight for no changing or moving etc needed. Or will fit but need to wiggle a few things.
- X8GGY
12 Jul 2016 12:26 #169917
Best to ask Russ at JimnyBits via his helpdesk then?...
- MattB12
12 Jul 2016 14:48 - 12 Jul 2016 14:51 #169919
by MattB12
Replied by MattB12 on topic Relocating air con pipe help
Hi David, I have that exact JimnyBits winch plate fitted to my 57 plate VVT - I think we are the same model even though different year, I have aircon too.
I didn't need to relocate anything, with the bumper off the plate slotted right in without anything in the way. After test fitting and securing it, I marked all the holes and drilled them. Just make sure you've got some nice sharp HSS drill bits.
After that it all bolted up nicely and now holds my 6000lb winch. The winch plate is a brilliant bit of kit though and very strong, i've pulled a stuck Pajero from the mud and put it to good use pulling a few tree stumps out the ground.
The plate remained solid.
Last edit: 12 Jul 2016 14:51 by MattB12.
- davert85
12 Jul 2016 17:24 #169927
by davert85
Thanks to both of you for replies, very helpful indeed. It is a fantastic mount
I had the exact same one with the exact same winch on my last Jim. I believe our Jims are the same model, 56 plate vvt.
The pics and info was and will be a great help.
Thanks again
Thanks again
Time to create page: 0.092 seconds
