How much brake fluid?
- Thank you received: 2004
10 years 4 months ago #169590
How much brake fluid? was created by Lambert
Thinking it's well over due to change the brake fluid, how much and what grade do I need with abs? Cheers.
10 years 4 months ago #169623
Replied by Lambert on topic How much brake fluid?
Nobody has ever changed the brake fluid and knows how much they used? Wow.
- mickt
10 years 4 months ago #169708
by mickt
Replied by mickt on topic How much brake fluid?
About a litre but it depends how much you use during bleeding!
10 years 4 months ago #169709
Cheers, i seem to think that the last car i did was a discovery and I used loads because I was at a mates garage with an unlimited supply and obviously the Jimny is significantly smaller so will hold less? Best buy a couple of litres to be safe i can always take it back unopened. Thanks again.
Time to create page: 0.083 seconds
