Deep sump pan for jimny.
- unsetlay
28 Jun 2016 02:11 #169231
by unsetlay
Deep sump pan for jimny. was created by unsetlay
It's in common to see a jimny with ATF cooler in my region, to prevent the over heating of trans.
How about to make a deep sump pan for jimny? does it help? what should I put in mind if I want to build one?
any advice would be greatly appreciated.
- Thank you received: 227
28 Jun 2016 02:53 #169232
by zukebob
Replied by zukebob on topic Deep sump pan for jimny.
The deeper sump and larger oil capacity will likely help the engine run a little cooler. Back when I first started with my 1976 FJ40 Land Cruiser, people would sometimes go with a deeper sump oil pan and it caused some improvement on the engine running a little cooler. Not a lot though. There might be a small parasitic effect on transmission temp but I don't think it would be significant.
The following user(s) said Thank You: unsetlay
- unsetlay
28 Jun 2016 03:24 #169233
by unsetlay
Replied by unsetlay on topic Deep sump pan for jimny.
Thank you for the reply, think you mean the oil pan of engine, we can only buy AT transmission here, so theres another pan for trans oil, wondering will it be more efficiency if deeper one.
28 Jun 2016 03:46 - 28 Jun 2016 03:48 #169235
by zukebob
Ah. Sorry. I thought you were asking about the engine oil pan. I honestly don't know if the amount you could possibly increase the fluid capacity in the transmission would be beneficial or not.
The Jimny auto transmissions (I have one too) do have a reputation of running hot. If the area of the world you live has a warmer climate, it does present an additional concern. I live in the Philippines but haven't really stressed my Jimny yet. I can tell you that I plan to monitor my normal Transmission temp while under mild stress and then install one of these:
It's an aluminum 2-row radiator. If that doesn't provide reasonable improvement, then I will go to one of the transmission coolers you mention and call it a day.
Wish I could give more (better) information,
Bob
Bob
Last edit: 28 Jun 2016 03:48 by zukebob.
Time to create page: 0.085 seconds
