water underneath the backseats
  • hudeck
26 Jun 2016 17:38 - 26 Jun 2016 19:18 #169169 by hudeck
water underneath the backseats was created by hudeck
hello,
i've searched the forum if their were any owners that have the same problem i have.
i have a suzuki jimmy soft top.
and the challenge / problem i'm having is as the subject is describing.
but i cannot figure out were the water is coming from?
how i discovered this is that i found some water stain underneath the car a couple of days ago.
first i thought it was the fuel tank that was leaking but then i thought it couldn't be, so i took the seat in the back out and discovered a lot of water/oil underneath it by the draining plugs.
so i cleaned all the water out and the problem was gone, but after a couple of days and some rain the water was back at that same place.
is there something i forgot to take a look at to solve my little challenge
Last edit: 26 Jun 2016 19:18 by hudeck.
26 Jun 2016 20:03 #169181 by mlines
I would guess washer non-return valve failed
Sent from my Nexus 6P using Tapatalk
  • hudeck
27 Jun 2016 06:27 #169192 by hudeck
Replied by hudeck on topic Re:water underneath the backseats
mlines wrote: I would guess washer non-return valve failed
Oké and where can i find that washer?
27 Jun 2016 22:01 #169228 by Johnniehec
It doesn't often happen but Martin's comment is wrong, he's suggesting the one way valve in the rear screen washer pipe, but yours is a soft top which doesn't have a rear screen wash.
I'd suggest it must be the soft top that is leaking somewhere and running down behind the side trim panels.
  • gusthegorilla
28 Jun 2016 01:35 #169230 by gusthegorilla
Replied by gusthegorilla on topic Re:water underneath the backseats
I've just had the side panels out of my latest Jim to check for corrosion before boarding it out, a d found a tiny hole in the nearside wheel arch ....a strong contender for water ingress :sick
Gus :)
28 Jun 2016 04:22 #169236 by Halford
I've also suffered from this, and still do but less by putting towels and carpet down. In my case pretty sure it's the result of condensation, the formation of water molecules from damp air on cold surfaces - happens a lot in the North UK at least. :(
Time to create page: 0.108 seconds
