Tyres and speedo correction.
  • Al.
22 Jun 2016 22:22 #169023 by Al.
Tyres and speedo correction. was created by Al.
205.70.15 stock size at 30mph indicated on the speedo, gps shows 26mph.
What would be the result if I fit 195.80.15.
Thanks
  • 1066Boy
23 Jun 2016 06:16 #169031 by 1066Boy
Replied by 1066Boy on topic Tyres and speedo correction.
A change of 3.7% so it will be a little closer but still not spot on.
At least you have a margin of error with the speed cameras. ;) .
  • helijohn
23 Jun 2016 17:00 #169049 by helijohn
Replied by helijohn on topic Tyres and speedo correction.
Al. wrote: 205.70.15 stock size at 30mph indicated on the speedo, gps shows 26mph.
Thanks
I use this.
www.autopartuk.com/tyre-calculator/
23 Jun 2016 17:18 #169051 by jackonlyjack
i fitted 195 80 15's retread 700mm tall
and speedo is same as reading off sat nav and the signs that tell you to slow down ;)
Jack
  • johna
29 Jun 2016 21:13 #169330 by johna
Replied by johna on topic Tyres and speedo correction.
Most cars err on the side of caution gps is the way for accuracy.
30 Jun 2016 10:16 #169338 by Busta
Replied by Busta on topic Tyres and speedo correction.
By law a new car's speedo must not under-read but they are allowed to over-read up to 10%. Obviously there are benefits to a manufacturer, by making the driver think they are going further/faster than they actually are, so some companies take more advantage of the 10% margin than others!
