Mechanic Wanted Wetherby/North Yorks
17 Jun 2016 08:46 #168714 by bryn
Anybody know of a good mechanic professional or otherwise in the Wetherby/North Yorkshire area who knows what he's doing with a Jimmy,
Thanks
bryn
18 Jun 2016 22:03 #168810 by bryn
Appreciated
thanks
bryn
19 Jun 2016 05:39 #168813 by Lambert
I qualified as a mechanical engineer and am only in Harrogate, what's up?
19 Jun 2016 06:41 #168814 by bryn
I had the king pin barings changed a couple of months ago and then 2 weeks ago the nearside started leaking lots of grease to the point by the sound of it there is little grease left (stopped driving it) so its going back in on monday to sort out. The garage said it was more likely the dust seal not seating right. I have spoken to a couple of people with Jimnys who say its more likely the internal seal. I've got all the bits for a full king pin baring change and hopefully they will sort it.
I wanted a good mechanic with a knowledge of Jimnys, for this and any other problem that may arise in the future.
Appreciated
bryn
19 Jun 2016 07:04 #168816 by Lambert
It is not going to be the swivel seal because as you said it is a dust seal. The issue will be with the inner axle oil seal that was worn and not replaced with the kingpins or was new and not seated properly or somehow damaged upon re assembly. Many garages are used to defenders and older discovery which are a different design and do rely on the swivel seal to keep oil in. Kingpins are not a particularly arduous job just messy and with due care are well within the ability of most home mechanics working on the drive, especially when undertaken with reference to the guidance on the wiki on this site. Let me know if you want me to have a look at it for a second opinion, but I would be looking to get the initial garage to cover redoing the job as on the face of it they have an obligation after such a short period since doing the job.
19 Jun 2016 16:33 #168842 by bryn
Thanks for the offer. Its going in on Monday and hopefully will be sorted. And I hope will not be charged.
bryn
Time to create page: 0.103 seconds
