Car died today - what might be wrong?
  • susie
17 Jun 2016 08:08 #168712 by susie
Hello everyone
Not been on here for a while and once again im hoping someone would be so kind to advice. My car is giving me problems again.
I drove it to work and when i stopped on a red light, the car died. Basically the dial indicator (the red thing showing on rev count) is quite low - below 1 and it went to 0 and cut out on me. What could be wrong? if anyone has any idea i would appreciate it.
  • mickt
17 Jun 2016 19:04 #168752 by mickt
Replied by mickt on topic Car died today - what might be wrong?
That is the rev counter and shows how fast the engine is going in terms of revolutions of the crankshaft. We would need a lot more info to diagnose your fault but to start with did you have fuel in the car? Was the engine cold, warm or hot? Any other symptoms like sluggish throttle response or even warning lights illuminating? Have you looked under the bonnet to check for belt failures or loose leads including the battery?
  • susie
17 Jun 2016 19:32 #168755 by susie
Replied by susie on topic Car died today - what might be wrong?
Hi thank you for replying.
I had enough fuel so thats not the issue. The car cut out probably 5 minutes after i set off from home so the engine wasnt too hot i dont think.
When it happened, the battery light and came on but i think that happens anyway because the engine cut out so some warning lights came on. The battery i have is probably 6 - 12 months old. The car has been ok since this morning but the dial on the rev counter is always pretty low- near 0 and sometimes it seems to go above 1 and then near 0 again (goes up and down within a second) and the car sort of shakes when this happens but im not sure what it means.
  • susie
17 Jun 2016 19:34 #168756 by susie
I havent checked the car yet - not sure what i should be checking
17 Jun 2016 23:28 #168770 by kirkynut
Hi Susie. Unfortunately from the little you are able to tell us all we seem to know is that the engine stops for no known reason.
I don't think we'll be able to diagnose it online for you. I think you need to get it to a garage for them to look at it properly.
Sorry!
18 Jun 2016 06:46 - 18 Jun 2016 06:49 #168772 by skywalker65
Hi Susie,
As Kirkynut says you may be better getting to a garage
From the bit of info we have it could be a wide range of things causing the fault. The most common being crank or camshaft sensors,plugs,coil packs if it is the M13 engine.
Dunno where your based but I'm sure someone on here could take a quick squint at it
If in doubt ...... Flat out ??
Last edit: 18 Jun 2016 06:49 by skywalker65.
Time to create page: 0.104 seconds
