Balance beads
  • helijohn
16 Jun 2016 19:41 #168685 by helijohn
Balance beads was created by helijohn
Since fitting my different rims to the front with almost new Enduros on them, despite balancing there is mild wheel wobble. Fine with the old set of rims and tyres though. Is it worth trying the beads to sort this? One of the front tyres was almost perfect balance wise. The other was the next best of the four, this is the one I suspect.
16 Jun 2016 21:20 #168692 by kirkynut
Replied by kirkynut on topic Balance beads
I use them in my Malatesta Kaimans as they are aggressive remoulds and find they work well.
Here's what I use:
www.devon4x4.com/off-road-store/wheels-t.../tyre-balancing.html
  • helijohn
16 Jun 2016 21:33 #168693 by helijohn
Replied by helijohn on topic Balance beads
kirkynut wrote: I use them in my Malatesta Kaimans as they are aggressive remoulds and find they work well.
Here's what I use:
Great link thanks. Worth a go! B)
  • helijohn
16 Jun 2016 21:40 #168694 by helijohn
Here's what I use:
Ah, have to break the bead. :(
  • OllieNZ
17 Jun 2016 09:24 #168717 by OllieNZ
Replied by OllieNZ on topic Re:Balance beads
I thought you could get beads that go in through the valve stem? Just take the valve out pour the beads in, reinstall the valve and inflate.
  • helijohn
17 Jun 2016 12:27 #168735 by helijohn
Replied by helijohn on topic Re:Balance beads
OllieNZ wrote: I thought you could get beads that go in through the valve stem? Just take the valve out pour the beads in, reinstall the valve and inflate.
Yes you can though two things; first is they recommend biggish beads for 4x4 tyres and those won't go through the valve. There is another firm who sells the smaller beads which apparently can be used but they are more expensive that the ones Rob linked me to.
I don't mind getting some as long as I know they are effective.
Time to create page: 0.105 seconds
