Bleeding brakes
10 years 5 months ago #168550
by facade
Bleeding brakes was created by facade
Make sure the bleed nipple is at the top, you may have to remove the calliper and rotate it.
One thing I've done on really stubborn systems is take the callipers off, pumped the pistons well out, then holding the fluid entry at the top, squeeze the pistons all the way back in, this should push any air right back to the master cylinder.
The professionals use a vacuum device to pull the air and fluid out at the nipple.
- BENNY
10 years 5 months ago #168574
by BENNY
Replied by BENNY on topic Bleeding brakes
Hi rich are the rover calipers and brake lines for sale..
10 years 5 months ago - 10 years 5 months ago #168585
by Halford
Replied by Halford on topic Bleeding brakes
I had to have the pro vacuum device used on mine and had to let gravity do its job fonor several hours on all 4 corners after having my new pipes fitted. The little diy bleed kit just wouldn't do the job
Last edit: 10 years 5 months ago by Halford.
10 years 5 months ago #168587
by facade
Replied by facade on topic Bleeding brakes
And get the pedal presser to rapidly pump the pedal, then stand on it with the nipple closed, then you open the nipple quickly and hope the air is compressed enough to shoot out.
If you do rotate the calliper, you need something solid between the brake pads
