Kingpin
  • Sutcliffe
09 Jun 2016 22:48 #168281 by Sutcliffe
Kingpin was created by Sutcliffe
Is greasing kingpin bearings with waterproof grease necessary? Or will it be fine if I don't grease them, thanks
10 Jun 2016 04:02 #168284 by Lambert
Replied by Lambert on topic Kingpin
First set I did with cv grease and they lasted less than 6 months on the bottom though the tops were Ok, this current set are waterproof grease and doing good at nearly 12 months including one of the wettest winters I can remember.
  • Sutcliffe
10 Jun 2016 09:39 #168291 by Sutcliffe
Replied by Sutcliffe on topic Kingpin
Okay I'll use wateproof grease! Thanks alot
11 Jun 2016 03:30 #168329 by kirkynut
Replied by kirkynut on topic Kingpin
You'll have to grease them with some type of bearing grease. You couldn't just not grease them!
As has been said, waterproof grease lasts longer. Especially if you go off road and through water.
Time to create page: 0.080 seconds
