how to set up adjustable panhards
- jewi
09 Jun 2016 10:24 #168248
by jewi
how to set up adjustable panhards was created by jewi
Im after a little bit of advice,
my jimny has a 3" lift but has always had standard fixed panhard rods fitted. I have just bought a second hand pair that were set up for a jim with 4" lift.
The question is, when they are fitted they will need adjusted but by how much?
i was thinking about putting a spirit level next to the wheel, measure the gap between that and the wing and make sure its the same on both sides.
Any help will be appreciated
Cheers
Paul
Cheers
Paul
- S200KYS
09 Jun 2016 11:26 #168259
by S200KYS
Replied by S200KYS on topic how to set up adjustable panhards
That's it Paul
Set your axle in the middle of the body and adjust the panhard rod to suit
I winch mine over until it's square in the middle and then set the rod to suit :evil: :whistle:
12 Jun 2016 15:36 #168410
by Keithy
Replied by Keithy on topic how to set up adjustable panhards
I extended the chassis mount to keep the bar level as it describes an arc....
- S200KYS
12 Jun 2016 16:36 #168412
by S200KYS
12 Jun 2016 19:23 #168433
by Keithy
But why would anyone need an adjustable one if the pivot point was lowered to level the rod?
S200KYS wrote: Me too, but that's not what he asked...
- OllieNZ
13 Jun 2016 05:31 #168458
by OllieNZ
Replied by OllieNZ on topic Re:RE: how to set up adjustable panhards
Because the stock ones are softer than butter? Most of the HD ones are adjustable and would require setting up even with extended brackets.Keithy wrote: But why would anyone need an adjustable one if the pivot point was lowered to level the rod?
Time to create page: 0.101 seconds
