M series vvt conversion Q
  • JimnyNZ
24 May 2016 07:03 #167354 by JimnyNZ
M series vvt conversion Q was created by JimnyNZ
Hi folks had a mild sj413 and now a 2006 prob jap import Jim. (NZ)
Over here we missed out on the m18 from what I can find but can get an m15 eng harness comp keys and ignition for a good price. Vac hubs etc aside could you plug and play or not?
Great site by the way
24 May 2016 12:44 #167369 by Busta
Replied by Busta on topic M series vvt conversion Q
Yes. You don't need anything other than the bare engine. All the manifolds, ancillaries, cooling bits, sump, rocker cover and flywheel are swapped from the old Jimny engine onto the 1.5. Use the Jimny ECU and loom. Use the 1.5 injectors and throttle body but keep the 1.3 throttle body just in case. The vac hubs will work as normal.
  • JimnyNZ
24 May 2016 23:24 #167418 by JimnyNZ
Replied by JimnyNZ on topic M series vvt conversion Q
Sorry didn't explain properly, can get the whole lot as a "jetboat" package was wondering about using the 15 with manifold ecu and key etc, possibly ign barrel if required. Pros are not much more than bare motor spare coils etc. Realise a out the sump rocker etc swap required. Was wondering if the ecu was interchangeable without worrying about vac hubs or are there other hidden pitfalls?
Assume they are straight out of Japan
24 May 2016 23:51 #167419 by zukebob
Replied by zukebob on topic M series vvt conversion Q
What Busta said is correct. You will need the Jimny ECU for the vehicle to operate properly. The file I attached probably contains more information than you want but is a condensed version of an engine swap detailed on another forum.
The link to that discussion is here and covers some of the ECU issues:
www.auszookers.com/forum/viewtopic.php?f...5160f9515d605ab42040
  • JimnyNZ
25 May 2016 05:45 #167423 by JimnyNZ
Thought I had well stalked that aus zook conversion thread, will have another look. Also will check out the other link provided when Mr 18mths is asleep on the laptop. I suppose essentially I was asking if man hubs and rock lobster what else did the Jim ecu control?? Air bags??
To save another thread I assume the Jim trans case and a geared one (SJ) put out too different signals to modify with a jaycar speedo correction kit?
You fellas a great BTW have met a few immigrant trade engineers...
25 May 2016 06:25 #167424 by zukebob
The initial discussion on ECU issues is on pages 3 and 4 of the thread I included. I believe there are some additional comments later.
Two points I should make to keep my comments in context. The first is that I haven't done a conversion myself. In the future I hope to swap my M13 non-VVT for a M16 non-VVT. The second, as pointed out in the Auszooker thread, is that it is likely possible to work out all of the ECU issues but it would be with a lot more effort and likely only a minor performance improvement (assuming you use the M15 throttle body with the M13 idle control valve).
Rhinoman may be along to answer some finer points on the ECU possibilities.
Time to create page: 0.101 seconds
