Snorkels
  • Horney
05 Jul 2016 10:09 #169575 by Horney
Replied by Horney on topic Snorkels
Bullyboy wrote: I just fitted the cheapest snorkel you can buy from Jimnybits. Seems ok and easy enough to fit, altho the fitting template was hand drawn then mass copied.
I've just bought this one also. Not looking forward to cutting holes int he car to make it fit. Any tips?
  • X8GGY
05 Jul 2016 13:38 #169580 by X8GGY
Replied by X8GGY on topic Snorkels
johna wrote: just a question, would you really need a snorkel, if you were that far in the water wouldn’t the Jimny float.
I know that they look quite good, or is that the reason for putting one on.
john
Depends where you're going to take your Jim' John...
(Same ford from different angles)
Yes, it floated a bit but then found some footing... but the engine still breathed through the snorkel, otherwise it would have sucked in (water) from the standard air intake position behind the driver's headlight in the wing, and water does compress like petrol and air mist, so BANG, hydraulic'ed engine, bent bits, etc...
  • X8GGY
05 Jul 2016 13:42 - 05 Jul 2016 13:47 #169581 by X8GGY
This IS (Brett) floating -
LOL :woohoo:
The sign says it all...
Last edit: 05 Jul 2016 13:47 by X8GGY.
  • Bullyboy
06 Jul 2016 07:22 #169618 by Bullyboy
Replied by Bullyboy on topic Snorkels
Only tips i can give you are measure 3 times before cutting. The template is not the best, hand drawn so is not %100 accurate. I used the original tube that comes out the back of the air filter. I just cut off the end of the long tube that extends toward the rear of the jimny and used the bit i cut off to block the original air intake. Then simply attach the hose from the snorkel to the cut off end.
  • Horney
06 Jul 2016 07:53 #169620 by Horney
Cheers. B)
06 Jul 2016 15:50 #169641 by Rhinoman
Replied by Rhinoman on topic Snorkels
john
It doesn't need to be that high for wading. The height helps keep the intake out of the worst dust when travelling with other vehicles, - not that much of an issue here in the UK but the Safari definitely an issue in some other countries.
Time to create page: 0.159 seconds
