That bl@@dy tyre question again
  • the_goshawker
19 May 2016 21:26 #167050 by the_goshawker
That bl@@dy tyre question again was created by the_goshawker
Sorry sorry sorry i know this has most likley been asked before but could you please let me know what the best pressure for my tyres, for
A-road use
B-Offroad
C-50-50 use
They are open country A/T 215/75/15. Thank you :)
19 May 2016 21:56 #167053 by jackonlyjack
20 May 2016 06:48 #167062 by Busta
Same size but BFGs, 50/50 use, 21 all round in the summer and 19 in the winter. I'll put them up to 23 for a long road trip. Purely off road, down to 15psi is sensible but I have run them as low as 12 on really boggy ground.
  • Sandro
20 May 2016 11:37 #167073 by Sandro
Replied by Sandro on topic That bl@@dy tyre question again
A 25psi
B 19psi
C 12psi
215/75 bfg km2 on 15x5.5 stock rims ... with 15x7 rims is better not going below 14psi ..
Yes, at 12psi you loose an half inch of ground clearance, but my experience is that low pressure tires make your car able to drag in deep roots better than same tire at higher pressure and half inch more clearance.
20 May 2016 15:09 #167075 by Lambert
On the side of the tyre will be be a maximum load at a given pressure. This information car be used in conjunction with the known maximum axle weight of the car and some maths to give you the correct pressure for the weight of the car.
Time to create page: 0.099 seconds
