Soft top press studs
- leftcase
19 May 2016 19:25 #167031
by leftcase
Soft top press studs was created by leftcase
I've grabbed a replacement soft top from Monsoon, and I've been checking out the instructions. Unfortunately half of the press studs on the Rear Hoop of the car have broken off and the new hood needs to connect to these. Anyone got any ideas how I can reattach new studs to the bar?
Cheers,
Chris
Cheers,
Chris
- gordonm
24 May 2016 15:48 #167381
by gordonm
Replied by gordonm on topic Soft top press studs
If I remember rightly when I got a replacement soft-top from Monsoon fitted at their premises, they supplied and fitted new press stud rails - I'd suggest giving Monsoon a ring, I'm sure they'd be able to supply the parts or at least advise 'what and where'
- Thank you received: 706
24 May 2016 16:00 #167384
Replied by jackonlyjack on topic Soft top press studs
No eBay APP ID and/or Cert ID defined in Kunena configurationmaybe something like this might help
Jack
Jack
24 May 2016 16:03 #167385
small pop rivet or counter sunk screw-self tapper or tap threadsleftcase wrote: I've grabbed a replacement soft top from Monsoon, and I've been checking out the instructions. Unfortunately half of the press studs on the Rear Hoop of the car have broken off and the new hood needs to connect to these. Anyone got any ideas how I can reattach new studs to the bar?
Cheers,
Chris
- leftcase
24 May 2016 17:20 #167387
by leftcase
Replied by leftcase on topic Soft top press studs
Thanks for the advice guys, but s200kys and gusthegorilla have collaborated to get a replacement to me. It's good to know the old one can be fixed though, so I'll keep hold of it in case anyone else needs it.
Thanks for your advice too gordonm but I've already got the side inserts with presstuds on from monsoon, it's the rear metal hoop where the presstuds have come off I needed.
Time to create page: 0.084 seconds
