Not engaging 4WD
19 May 2016 14:21 #167015 by furo
Not engaging 4WD was created by furo
Hi folks,
I just got my Jimny back from the garage a couple of days ago, having had shocks/springs challenged and a service, and I've noticed that it is no longer engaging 4wd (high or low). What is the most likely culprit and where should I look? I'm a complete novice, but I'd like to fix it myself if possible.
Thanks in advance
  • mickt
19 May 2016 14:42 #167016 by mickt
Replied by mickt on topic Not engaging 4WD
Have you been back to the garage as they might have knocked a vacuum pipe or something simple whilst doing the shockers.
  • Tom1357
19 May 2016 16:54 #167022 by Tom1357
Replied by Tom1357 on topic Not engaging 4WD
As above, easiest thing to knock or damage would be the vacuum lines which go to the hub, after that you have the plugs and sensors on the transfer box but it'd be a lot harder to knock these.
25 May 2016 19:57 #167491 by furo
Replied by furo on topic Not engaging 4WD
Thanks a lot guys! Turned out the vacuum lines were really corroded and one had been broken when the shocks were fitted. I took it back to the garage and they fixed it for free.
  • Daniel30
25 May 2016 21:48 #167497 by Daniel30
Replied by Daniel30 on topic Not engaging 4WD
Result well done :woohoo:
Time to create page: 0.092 seconds
