Track rod ends
- Unrealmcoy
15 May 2016 08:53 #166789
by Unrealmcoy
Track rod ends was created by Unrealmcoy
Hello all,
So the MOT is due and looks like the Jimny is going to need track rod ends all round.
Despite my best efforts I can't find any info on this topic.
Are the rod ends the same part front to back / side to side?
There seems to be two Suzuki part numbers for the rod ends (48810 - 81A01 - 000) and also (48820 - 81A01 - 000) which leads me to beloved one side of the car is left hand thread and the other is right hand thread?
Don't want the headache of a part that doesn't fit!
Any info is appreciated
15 May 2016 09:15 #166792
Replied by mlines on topic Track rod ends
Yes. There are left hand ones and right hand ones.
See in my shop for details
Aftermarket ones here..
www.bigjimny.com/store/tie-rod-ends-suzuki-jimny-rh.html
www.bigjimny.com/store/tie-rod-ends-suzuki-jimny-lh.html
Genuine Suzuki here...
www.bigjimny.com/store/tie-rod-ends-suzuki-jimny-lh-p255.html
www.bigjimny.com/store/tie-rod-ends-suzuki-jimny-rh-p256.html
Instructions here...
www.bigjimny.com/images/documents/changing_a_tie-rod_end.pdf
15 May 2016 10:08 #166797
Replied by Daniel30 on topic Track rod ends
How do you know when your track rod ends need replacing?
- Unrealmcoy
15 May 2016 13:07 #166810
by Unrealmcoy
Replied by Unrealmcoy on topic Track rod ends
Cheers,
A lot of the part descriptions online don't fully explain wether they are left hand thread or For the left hand side of the truck
I'll take a look at them.
- Unrealmcoy
15 May 2016 13:10 #166811
by Unrealmcoy
If the boot is split or isn't containing grease then its an MOT fail.
If you wipe them off before it goes for test the tester might not notice.
Thing is they're so cheap there isn't much point.
15 May 2016 13:23 #166812
Ah ok, mine have a bit of grease coming out of them so I'll keep an eye on them
