front brake discs
- Davyo
12 May 2016 13:49 - 12 May 2016 13:51 #166632
by Davyo
front brake discs was created by Davyo
Help I bought a set of front discs and pads off the bay of evil.They are identical to that taken off but the new ones won't bed in right ( sitting about 40mm off so not flush with the hub.I think it's the shamphered bit that fits snug round the vacuum hub.Am I missing something or have I been sent wrong discs.The box states jimny 98- & vitara.
Last edit: 12 May 2016 13:51 by Davyo.
12 May 2016 13:54 #166633
Replied by mlines on topic Re:front brake discs
Two different sized discs on the Jimny . 107mm centres and 108.3mm , you have to get the correct ones
Sent from my Nexus 6P using Tapatalk
12 May 2016 14:03 #166634
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re:front brake discs
As martin says the early discs won't fit a later jimny. I think it changed when the abs was brought in.
Grey pick up Jimny
- Davyo
12 May 2016 14:04 #166635
by Davyo
Replied by Davyo on topic Re:front brake discs
Thanks mate just goes to show don't trust the compatability drop downs on ebay.Seller not responding also so looks like I'm £43 out of pocket.It 2008 model so presume I need 108.5mm centre.
12 May 2016 14:09 #166636
www.bigjimny.com/store/brake-disc-suzuki-jimny-108-3mm.html
Enter a Paypal/Ebay dispute process as "not as advertised" - they were advertised for your model and are not.
The dispute process usually favours the buyer and if nothing else prompts the seller to reply
- Davyo
12 May 2016 14:23 #166637
by Davyo
Cheers lads
I've order a correct set through my local car bitz &£19 each.Martin will the pads be OK though that came with the eBay wrong discs?I might just keep the pads and use them with the correct discs as they will be here in the morning.I suppose I could try and sell the eBay discs on here , if I get £20 back I'll be happy.
