Front differenti al measurements
  • Sandro
10 May 2016 09:31 #166463 by Sandro
Front differenti al measurements was created by Sandro
Hi everybody.
Can Simeone be so kind to measurements for me a standard jimny front diff (10 bolt model, thus aftermarket 2003)
I need the measurements marked as 1,2,3 in the attached drawing, trying to understand if a rear 4 pin carrier can fit the front 3rd member ...
Thanks
10 May 2016 17:09 #166482 by j999pre
I believe that you can make a 4 pin diff using a rear. However someone please correct me if I'm wrong.
Grey pick up Jimny
  • Sandro
11 May 2016 08:11 #166543 by Sandro
Replied by Sandro on topic Front differenti al measurements
I measured a rear diff
it is quite simular to the front One, except that the sidebearing ID is 45mm for the rear an 41mm for the front ... the front one was an 8 bolt, but the bearing code is the same of the 10bolt ...
Do you think that machining the side tubes to fit the front bearings can made them weak?
The thickness of the side tubes is 7.5mm ... should be reduced to 5.5mm ... :blink:
12 May 2016 12:14 #166629 by Busta
Rockwatt will know, I'm interested in doing the same.
  • Sandro
12 May 2016 18:46 #166673 by Sandro
Just got some tips from Rockwatt. The outer tubes, where the side bearings have to fit, should be machined to the correct diameter, then, a little bit of materiale should be removed from ring side face, in order to give some room for the backlash adjustment/preload.
Being the case cast iron, there should be no particolar problems. Then you will have a 4pin diff with 26spline side gears, ready for uprated shafts, and several lockers options ...
Time to create page: 0.091 seconds
