Vibes
09 May 2016 06:53 #166404 by facade
Replied by facade on topic Vibes
Daniel30 wrote: I can feel some quite strong vibration if I need to put my foot down in first and second only for the first few seconds and then it goes
Mine did this for a while until the crankshaft pulley came apart :ohmy:
The following user(s) said Thank You: Daniel30
09 May 2016 07:02 #166407 by Busta
Replied by Busta on topic Vibes
Sounds like the gearbox mount to me. It's easy enough to check if you can lay under the car- just try to lift the output end of the gearbox.
  • Daniel30
09 May 2016 07:51 #166408 by Daniel30
Replied by Daniel30 on topic Vibes
Thanks Gents will check the gearbox mount
Don't suppose you can check the pulley?
09 May 2016 09:44 #166411 by facade
Check the gearbox mount first as advised.
My pulley vibration was high pitched, not a shudder and was accompanied by a screech, and happened whilst accelerating hard in 1st & 2nd. It always looked fine to me, right up until the outer parted company with the inner :ohmy:
  • 1066Boy
10 May 2016 16:28 #166480 by 1066Boy
Replied by 1066Boy on topic Vibes
Just fitted the HD transfer mounts and had a little run. :)
It felt lovely and smooth so it may well be the gearbox mount as suggested. :(
  • Daniel30
10 May 2016 17:46 #166485 by Daniel30
1066Boy wrote: Just fitted the HD transfer mounts and had a little run. :)
Ok thanks for confirming if it stops bloody raining I'll have a look tomorrow :)
Time to create page: 0.101 seconds
