More gearbox trouble
- Lazia23
04 May 2016 17:01 #166237
by Lazia23
More gearbox trouble was created by Lazia23
probably a stupid question but...
as i pull out of a junction i get a deep rumble from the gearbox. At first i thought it was the transfer box that had come loose but no. Jacked her up this afternoon and there's oil flung all around the rear of the gearbox where the drive shaft comes out. can't see the back of the gearbox thanks to some sort of guard, but am i right in thinking there's a bearing there that is knackered?
Second thing, how do you check gearbox oil level? Oh its a 2001 JLX manual
Many thanks,
WIllem.
Many thanks,
WIllem.
- gilburton
04 May 2016 19:32 - 04 May 2016 19:34 #166240
by gilburton
Replied by gilburton on topic More gearbox trouble
Chances are the output bearing is worn.
You'll also need the seal as well. Possibly the seal has been leaking and the oil has leaked away causing the bearing to wear??
Might be easier to get a used box??
The Big Jimny shop carry the bearing and seal but it's closed at the moment.
Undo filler plug and fill until it drips out.
www.suzukiclubuk.co.uk/forum1/viewtopic.php?p=89679
Last edit: 04 May 2016 19:34 by gilburton.
Time to create page: 0.069 seconds
