4WD!!
  • Hunter203
10 years 6 months ago #166147 by Hunter203
4WD!! was created by Hunter203
So I think the 4wd is not working on the jimny :( put it onto a wet field in to 4H and the front wheels didn't seem to spin, while the back did :unsure: is this normal? any way I can check for definite?
Cheers!
10 years 6 months ago #166148 by Busta
Replied by Busta on topic 4WD!!
Put it in 4wd. Jack up one front wheel. If it spins freely 4wd is not working.
  • Hunter203
10 years 6 months ago #166152 by Hunter203
Replied by Hunter203 on topic 4WD!!
Nice one mate cheers! Shall check in my lunch break
  • Hunter203
10 years 6 months ago #166155 by Hunter203
There a slight bit of travel either way but it locks, cheers for the advice!
10 years 6 months ago #166178 by Busta
Sounds fine! There's always a small amount of movement due to play in the driveline.
10 years 6 months ago #166210 by Johnniehec
Replied by Johnniehec on topic 4WD!!
Maybe the passenger side front wheel was spinning and you couldn't see it.as Busta says the test you did proves everything's working as it should.
Time to create page: 0.082 seconds
