Why the shim?
- leftcase
30 Apr 2016 21:39 #166065
by leftcase
Why the shim? was created by leftcase
I've done some reading about the 'death wobble' and the Jimny I purchased a couple of weeks ago is definitely suffering from it. When I get to around 45ish MPH I get a lot of vibration and this seems to reduce at 52ish MPH.
Reading about fixes, I got myself some bits, king pins, king pin bearings, oil seal, swivel hub seal etc and when we finally have a nice couple of days I'll give it go. I've also read that shims are suggested.
Just wondering if I need these or not and if some kind soul could explain why?
01 May 2016 06:38 #166069
Replied by Riccy on topic Why the shim?
im no expert but i believe the shims are a sort of last resort fix if you have tried kingpin bearings and wheel bearings.
I had the same problem you describe and Martin sorted me out with the bits, and he suggested trying the kingpins and bearings first. I did as instructed and it sorted the problem out. If i was super picky i would say it still has a very slight wobble on rough tarmac roads, but i am running 215/75r15 BF AT's so i suspect thats the reason (or the mud stuck to the wheels!)
be wary of breaking the ABS sensor when you take it to bits (if you have ABS). they have a really weak bolt holding them in place
finally... if the shaft oil seal is gone then do a diff oil change at the same time, it will need it!
The following user(s) said Thank You: leftcase
- leftcase
01 May 2016 10:11 #166077
by leftcase
Replied by leftcase on topic Why the shim?
Makes sense. Thank you. I'll replace the king pins and bearings first and see how it is. Good call on the diff oil. I'll do that too.
02 May 2016 12:58 #166117
by kirkynut
Replied by kirkynut on topic Why the shim?
Shims are a way of taking up slack in the kingpin bearings. The hubs with new bearings in still allows an amount of slack by design and when Suzuki put bigger wheels on a Special Edition they developed shims because they had Death Wobble.
I would use annealed copper washers as they compress to just the right size.
- rayz_x
03 May 2016 13:51 #166162
by rayz_x
Replied by rayz_x on topic Why the shim?
Possibly a stupid question... but have you tried everything else? I had the same and it stopped when I rotated the wheels to different corners. Check balancing and tyres etc.
Ray
Ray
03 May 2016 18:54 #166198
Replied by Daniel30 on topic Why the shim?
Check tyre pressures
