Alternator Options
  • vdl
27 Apr 2016 11:50 #165890 by vdl
Replied by vdl on topic Alternator Options
Basketcase wrote: Do you know what the terminals are for the Vauxhall alternator?
two positive terminals and one sense/starter terminal - jimny plug does not fit - used only one wire from jimny plug for sense. don't rememeber which one. you should look in wiring diagram which wire is used for sense.
  • Basketcase
27 Apr 2016 13:33 - 27 Apr 2016 13:39 #165892 by Basketcase
Replied by Basketcase on topic Alternator Options
Cheers! Where on the alternator does the sense wire go? Which is the sense terminal?
Last edit: 27 Apr 2016 13:39 by Basketcase. Reason: Mia read other post!
27 Apr 2016 23:57 #165906 by zukebob
Replied by zukebob on topic Alternator Options
The sense voltage / field excitation current should normally connect to the black/white lead (IG) on the Jimny plug. I will let vdl confirm.
Time to create page: 0.095 seconds
