Front axle location?
  • 1066Boy
24 Apr 2016 17:19 #165747 by 1066Boy
Front axle location? was created by 1066Boy
Hi all, quick question. :unsure:
After fitting larger tires i have noticed that the arch clearance is not even between the
o/s and the n/s. The n/s has 2" at the rear (mud flap area) 1.5" to the bumper.
o/s is the reverse, 1.5" to the rear, 2" to the bumper. Its as if the front axle is out
of alignment. Is this normal and i have just never noticed it before? :blink:
  • TomDK
24 Apr 2016 17:52 #165751 by TomDK
Replied by TomDK on topic Front axle location?
You can't use these measurements for anything.
You need to measure the distance between radius arm mounts. axle to chassis.
24 Apr 2016 18:11 #165753 by Rhinoman
Replied by Rhinoman on topic Front axle location?
Are you running a lift without an adjustable panhard rod?
  • 1066Boy
24 Apr 2016 18:45 #165754 by 1066Boy
Replied by 1066Boy on topic Front axle location?
Rhinoman wrote: Are you running a lift without an adjustable panhard rod?
Yes a 2" procomp lift.
  • 1066Boy
24 Apr 2016 18:49 #165756 by 1066Boy
TomDK wrote: You can't use these measurements for anything.
????? :blink: Location of the wheels within the arch was the question hence the measurements! ;)
  • OllieNZ
24 Apr 2016 20:12 #165761 by OllieNZ
Replied by OllieNZ on topic Re:RE: Front axle location?
What TomDK is saying is to find out if the axle is out of alignment you need to check it from a reliable datum. The plastics attached to the body and even the body itself is not a reliable datum.
