Jimny Soft Top Press Studs
- leftcase
23 Apr 2016 15:18 #165686
by leftcase
Jimny Soft Top Press Studs was created by leftcase
Managed to find a few hours today to tinker with the Jimny, replaced the leaky rocker cover gasket and decided to remove the delapidated soft top to see how jiggered it really was.
The soft top definitely needs replacing, but I've also discovered that a couple of the press stud 'halves' sitting on the actual middle framework bar have corroded off, so there's nothing to secure the canvas side press stud 'halves' on to.
Just wondering if this is something that can be repaired, or do I need to be on the lookout for a new framework bar?
Thanks,
Chris
Thanks,
Chris
- gordonm
25 Apr 2016 14:27 #165792
by gordonm
Replied by gordonm on topic Jimny Soft Top Press Studs
I had a new set of 'tops' made and fitted by Monsoon at their premises, and they replaced all of the studs on the bodywork as part of the fitting (for extra cost) - made a fantastic job of it too!.
Time to create page: 0.071 seconds
