ELM 327 ( OBD2) Does not work in jimny
20 Apr 2016 07:37 #165516
by Mr.m.y
ELM 327 ( OBD2) Does not work in jimny was created by Mr.m.y
Hi
There is any scanner similar to ELM 327
Can read 2013 Jimny ECU
Thank you
Thank you
22 Apr 2016 10:42 #165627
by Mr.m.y
Replied by Mr.m.y on topic ELM 327 ( OBD2) Does not work in jimny
22 Apr 2016 19:47 #165653
by Rhinoman
Replied by Rhinoman on topic ELM 327 ( OBD2) Does not work in jimny
Whereabouts are you and what market was your Jimny built for? EOBD/OBD2 is only added for markets that legislate it, its limited in data and generally slower than OBD1.
23 Apr 2016 05:20 #165671
by facade
Replied by facade on topic ELM 327 ( OBD2) Does not work in jimny
Is that a bluetooth version??
I have a bluetooth one, that
1) will not, never ever work with my iphone, something to do with Apple not implementing bluetooth properly.
2) will connect to my Android tablet, but won't connect to any of the 3 cars I tried it in.
The £12 maxiscan ms309 copies work fine in all my cars to read & clear codes.
- leftcase
23 Apr 2016 15:22 #165687
by leftcase
Replied by leftcase on topic ELM 327 ( OBD2) Does not work in jimny
Bluetooth ones do tend to be a bit dodgy. I'd invest in a USB one. You can get them for less than a tenner from gearbest.com but they do take a while to come.
- Syfon
24 Apr 2016 08:28 #165723
by Syfon
Replied by Syfon on topic ELM 327 ( OBD2) Does not work in jimny
I got this one and works with my Jimny 2008, I've tried reading fault codes, also works with father's Volkswagen, I used android Torque app, I had some problems with compatibility, so sometimes it is good to try it on more smartphones.
Time to create page: 0.343 seconds
