Help! Very confusing problem!
- M19CHG
10 years 7 months ago #165460
by M19CHG
Help! Very confusing problem! was created by M19CHG
Went off-roading today in the Jim, was going fine until suddenly when in 4wd the front end started clicking and I couldn't steer properly! At one point when in four the drivers side wheel wouldn't move at all! Once back in 2, it Felt like the hub wasn't disengaging correctly! Managed to limp it home, all the way home there was a clicking noise from the right hand side! Took the locking Hub off and all seems fine, it was engaging and disengaging correctly but I can only do one rotation of the steering wheel to the left before it stops, but can get to full lock right, in 4 or 2! So confused! There is some play in the wheel bearing so going to change that, but can anyone suggest anything?
- Thank you received: 706
10 years 7 months ago #165461
Replied by jackonlyjack on topic Help! Very confusing problem!
sounds like a broken cv joint
Jack
Jack
- M19CHG
10 years 7 months ago #165462
by M19CHG
Replied by M19CHG on topic Help! Very confusing problem!
My gut feeling was that, very similar noise to back in my boy racer days when my Saxo used to get through a cv once every few months! Reckon it could be a case of regreasing or a new cv?
10 years 7 months ago #165463
hard to say till you remove and have a look
but if you can't steer both ways free it needs a new one
if i was you i'd check other side as well
Jack
Jack
Time to create page: 0.077 seconds
