Jimnybits disc conversion
  • Tommo
16 Apr 2016 12:30 #165399 by Tommo
Replied by Tommo on topic Jimnybits disc conversion
is there any preference on which caliper I bleed first?
  • X8GGY
16 Apr 2016 12:33 #165400 by X8GGY
Replied by X8GGY on topic Jimnybits disc conversion
Nice one B)
Be a lot easier to do oil seals again with the disk conversion!
Did you buy the kit recently? Did it come with spacer shims for the ends of the driveshafts?
  • X8GGY
16 Apr 2016 12:34 #165402 by X8GGY
Tommo wrote: is there any preference on which caliper I bleed first?
I never bleed my own brakes?! Someone should be along soon... ;)
  • Tommo
16 Apr 2016 12:39 #165403 by Tommo
yes I bought the kit recently, So I have the spacer shims,
well i'm going to have todo the brakes, other wise when I drive to work on monday it's not going to stop!
  • OllieNZ
16 Apr 2016 12:42 #165404 by OllieNZ
Replied by OllieNZ on topic Re:RE: Jimnybits disc conversion
Depends on which model. If you have a load sensing valve you need to start there, then start with the caliper furthest from the reservoir.
  • Tommo
16 Apr 2016 17:15 #165409 by Tommo
ah well it's a 2003, i dont know if that helps, i've now completed the job, and that was hard enough for me haha
I did the off side first, then near side, I did it untill there was no more air coming out the pipe, but I was expecting the rear brakes to be stronger than they are.
I know most of the braking is done from the front, but my drums were non existent, my brakes feel the same.
However, I finally have a handbrake that works!!!
I've minor busted an oil seal, so i'm going to get my friend who normally does all the work on my jimny to give it it's over due service and check my work. There doesn't seem to be any leaking, I had to grind the calipers quite alot to make the 15x7 rim fit
I have these, which I thought other than the 8 spokes, they are exactly the same offset and size as the standard modular that comes on the jimnys?
www.tyresdirectuk.co.uk/shop/wheels/15x7...ff-torque-8-spoke-2/
Time to create page: 0.114 seconds
