Front Diff Filler Plug
- auchenblae
- Elite Member
- Thank you received: 25
10 years 7 months ago #165284
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Front Diff Filler Plug was created by auchenblae
Sorry ment to post here but posted this on Chat.
Two years ago the front diff filler plug did not want to move using a square tool and it was replaced with a filler plug that had a nut on it a mate had in his box of bits. I thought he had welded a nut to it!
Now the rear diff filler plug will not move, it moved easily 2 years ago. I have a10mm square tool it is not a problem with using a 3/8 square tool that is too small.
I want to replace the rear filler plug with one that had a bolt face rather than a square cutout.
Can anyone advise a seller of such or the thread size and pitch of the diff filler plug.
eddie
eddie
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
- slew53
10 years 7 months ago #165295
by slew53
Replied by slew53 on topic Front Diff Filler Plug
Seem to remember it looks like 3/8 BSP if you know someone that does gas or near a heating/plumbing spares place they will do them.
10 years 7 months ago #165305
by facade
Replied by facade on topic Front Diff Filler Plug
The filler is more likely a BSPP (British Standard Parallel Pipe) thread as it has a flange & a nylon washer as a seal.
The drain plug and the gearbox filler are bound to be BSP as that is a taper, and Japan generally use BSP threads: they require sealant on the thread.
Time to create page: 0.079 seconds
