Spark plug gasket
  • leftcase
11 Apr 2016 19:15 #165213 by leftcase
Spark plug gasket was created by leftcase
Hey all,
Apologies in advance if anything doesn't make sense, but I'm a rank amateur at all this.
I bought an poorly maintained Jimny recently and so spent a chilly Saturday evening with a mate doing the routine service items air filter, oil change, oil filter, spark plugs, and when removing the old spark plugs noticed that a) they were loose and b) a couple had oil on them.
There's oil on top of the gearbox where it looks to have dripped down from the rocker cover so it looks like the rocker cover gasket needs replacing.
I've found a Jimny service manual online and it says:
"Install new spark plug hole gaskets (1) and new cylinder head cover gasket (2) to cylinder head cover (3) as shown in figure."
I've located the rocker cover gasket at here at Euro Car Parts , but I can't find the "spark plug hole gaskets". Does anyone have an idea where I might be able to get them from?
11 Apr 2016 19:49 #165218 by Rhinoman
Replied by Rhinoman on topic Spark plug gasket
Try sending a PM to Martin Lines at the bigjimny shop.
The following user(s) said Thank You: leftcase
  • minitehnicus
11 Apr 2016 19:54 #165222 by minitehnicus
Replied by minitehnicus on topic Spark plug gasket
Suzuki P/N is: 11179-71C01.
  • leftcase
11 Apr 2016 19:56 #165223 by leftcase
Replied by leftcase on topic Spark plug gasket
Brill. Thanks guys.
  • leftcase
11 Apr 2016 20:07 #165224 by leftcase
No eBay APP ID and/or Cert ID defined in Kunena configurationI'm guessing this is the fella:
  • streetfighterjeff
11 Apr 2016 20:34 #165226 by streetfighterjeff
Replied by streetfighterjeff on topic Spark plug gasket
looked at the title and thought you meant the copper washer on the plug. d'oh
Time to create page: 0.096 seconds
