VVT Engine down on power
- skywalker65
Topic Author
- Premium Member
- Thank you received: 20
11 Apr 2016 18:28 - 11 Apr 2016 18:30 #165207
by skywalker65
If in doubt ...... Flat out ??
VVT Engine down on power was created by skywalker65
Any thoughts on this one guys.
Jimny is well down on power. Starts ok but won't rev past 3k. It's only got 42k on it. Recent stuff that's been done. Valve clearances ok. Plugs,coil packs,crank sensor and oxygen sensor changed over the year due to other issues. No EML on. Not had chance to blag a scanner yet. Air filter is good. Gets to around 3k and it feels like it's hit a wall.Won't pull. Tried disconnecting air flow sensor and MAP sensor but all that does is throw a light up. Put a new cat on when I got it as the other one had fell to bits. When I had the coil pack break down the cat did glow a bit but it's been as good as gold last couple of thousand. Does the VVTmechanism rely on the cam sensor at all. Just wondering wether the 2 might be linked. Tried swapping the coil packs to eliminate that but it doesn't feel like an ignition issue more a fuelling one. Smells rich but that could be down to excess fuel getting dumped down the exhaust possibly. Any clues ??
Last edit: 11 Apr 2016 18:30 by skywalker65.
11 Apr 2016 19:50 #165219
by Rhinoman
Replied by Rhinoman on topic VVT Engine down on power
It does sound like a cat issue, try holding your hand over the end of the exhaust to see if its blocked or remove the O2 sensor.
- wombat
11 Apr 2016 21:06 #165233
by wombat
Replied by wombat on topic VVT Engine down on power
+1 on it being the cat, if you,ve had it glowing it could have melted it, thus blocking it . Had this problem with an rx 7 and the problem was faulty spark plugs, which knackered a new cat
- skywalker65
Topic Author
- Premium Member
12 Apr 2016 05:22 #165242
by skywalker65
Replied by skywalker65 on topic VVT Engine down on power
Cheers guys. Kept the original front pipe as the hangers had bust on it but it'll do as quick test. Looks like it's a job for next weekend
- skywalker65
Topic Author
- Premium Member
17 Apr 2016 12:37 #165441
by skywalker65
Thanks Chaps, You were correct. Front cat in the manifold had collapsed and blocked the other one. So just gonna get new downpipe one as the manifold one has gone on to another dimension
17 Apr 2016 13:01 #165443
Replied by Daniel30 on topic VVT Engine down on power
Glad it's sorted
Well done everyone
Well done everyone
