Gearbox service
10 years 7 months ago - 10 years 7 months ago #164751 by Mike G
Gearbox service was created by Mike G
Hi Gents,
In the future, I'm considering an engine upgrade to a 1.6. I'll be keeping the original gearbox and would like to have a tinker with it myself and replace the bearings, seals and quite possibly some synchro rings (depending on their state). The way I see it, I'm not going to learn about it unless I research and physically work on it. However, if I break it beyond repair, I'll just have to consider getting a new one. The point of this exercise is to learn a little more about the internals of the jimny box. I have an expert on gearboxes available to guide me if I get stuck. But my question is this:
I found a set of bearings in a kit on ebay for 2005> jimny, which my one is. Couldn't see a kit on bigjimny shop and wondered if Martin had anything like this available as I'd rather buy from the shop to support the site.
The gearbox bearing kit is here
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Last edit: 10 years 7 months ago by Mike G.
  • minibbb
10 years 7 months ago #164754 by minibbb
Replied by minibbb on topic Re:Gearbox service
Does your box show symptoms of needing repair?
My gear change isn't amazing however other than an oil change I'll try not to touch anything. M13 boxes are sub £100 so I would rather drop a replacement in!
10 years 7 months ago #164755 by Mike G
Replied by Mike G on topic Re:Gearbox service
Hi,
I'm not sure if it's the gearbox or the clutch at the minute, but I'm going to replace the clutch soon. Going into second, there's a little crunch sometimes, which makes me think that the cone on the synchro ring is worn and not getting enough friction on that change. Also when moving into fourth gear, sometimes it feels a bit muddy and vague, can't tell if it's actually going into gear. Hopefully a clutch change would sort it out, but I like to look ahead a little, just in case. Glad to hear an M13 box can be that cheap, this is why I love my Jimny so much. Would that be the R72 box?
Time to create page: 0.076 seconds
